suzuki samurai yj springs
hello
can any one help me with yj springs , i have questions about the conversion
like do i need to do anything to the steering , how hard it is to fit and will the zuki still be uk road legal ??
im looking at a kit on the low range off road site , are they any good ?? will i be charged a fortune for import charges or is there someone that can do it in this country
http://www.lowrangeoffroad.com/sky-yj-l ... -kits.html
many thanks
luke
many thanks
luke
Re: suzuki samurai yj springs
I think that *technically* you are supposed to register the vehicle as a radically altered vehicle whenever you change things like the suspension, do an engine swap (for something non-standard) etc, but the reality is that the DVSA don't seem to care as long as your MOT man is happy, and your vehicle is built within the rules (nothing sharp poking out, wheels covered appropriately etc).
https://www.gov.uk/vehicle-registration ... d-vehicles
I think I'd like to do a YJ conversion on mine someday. Someday...
Bolt on kits are fine as you aren't modifying the chassis.
If staying spua then the steering can be left stock.
It's nowhere near as strict as that, engine swap you just need to register the new capacity and fuel type.Anton wrote:I think that *technically* you are supposed to register the vehicle as a radically altered vehicle whenever you change things like the suspension, do an engine swap (for something non-standard) etc, but the reality is that the DVSA don't seem to care as long as your MOT man is happy, and your vehicle is built within the rules (nothing sharp poking out, wheels covered appropriately etc).
It only becomes radically altered if you modify the chassis or you change enough parts that you don't have enough original parts to keep the 8 points you need.
In reality there's 1000s of vehicles on the road that should have had an IVA on them so who cares....it's best we just don't even mention it.
- kernow_joe
From looking doesn't look to hard at all to fit at all, I'm trying to talk myself into, going to have to start saving up I reckon!
The YJ swap is a doddle. I fitted the sky kit from low range.
Few issues with bolt sizes, i just drilled them out to the next metric size up and used bigger bolts.
The front drop link shackles are garbage, mine are currently pinned but i will be welding them up.
Overall it's a much softer ride and a lot more flex.
Things to note
- none of the bolt on kits have shock mounts on the plates, need to make some / re-use the standard ones
- depending on the tyre size being run the additional width of the springs can make a noticeable difference to steering lock / turning circle
- my kit moved the front axle forward and required a prop spacer
- most likely longer shocks and brake lines required
Things to note
- kernow_joe
Nothing to drastic then with fitting.
Is that the drop links they supplied, or drop links in general that are crap?
Whats the issue with them?
Drop links in general are rubbish in my opinion.
The ones supplied are particularly bad, on full droop they have on occassion folded "inside out" if that makes sense.
- kernow_joe
Yeah I couldn't see that working too well, so they don't have a 'guard' like these then?
I thought the added droop could be good off road?
The actual gains from uncontrolled droop travel with no spring rate are so minimal that the negatives outweigh the positives by quite a margin in my opinion. TBH I fail to see any gains anyway, there's not much point a tyre being on the ground of it has next to no ground pressure especially in off camber and axle twist situations, correctly set up bumpstops increase the ground pressure a bit because of the fulcrum effect however as soon as there's a weight shift off the dropped wheel there's no ground pressure at all or spring rate to control said weight shift.
No matter what people say it is possible for them to open up on climbs, drops and side slopes as well, I've seen it happen and driven an sj with dflex style shackles that i could constantly hear and feel opening and closing, it wasn't nice.
I built my YJ set up without missing links and love it, yes I lift a wheel now and again but it always feels in control and I know exactly what it's going to do.
It's got a nice amount of flex as well.
- IMG_6759.JPG (102.44 KiB) Viewed 8343 times
- IMG_6762.JPG (191.7 KiB) Viewed 8343 times
- IMG_6760.JPG (206.77 KiB) Viewed 8343 times
