More than one Auto window
ipbr21054
Post by ipbr21054 » Wed Dec 06, 2017 7:42 pm
Suzuki Grand Vitara 2004
Hi,
Do you know of a modification so I can have two front auto windows as opposed to just drivers side.
Thanks.
Grand Vitara,54 plate,2000cc,Manual,5 Door,Air Con,4WD.
Re: More than one Auto window
Post by ScottieJ » Thu Dec 07, 2017 12:49 pm
I thought most GVs had electric windows all round? Never known one with just the driver side window. wouldn't be too hard to get parts from another GV to fit them all though.
Ladaman
Post by Ladaman » Thu Dec 07, 2017 1:55 pm
I think he might be meaning, when you press the button for about a second it automatically goes all the way down, without having to hold it all the time.
Maybe.
zook123
Post by zook123 » Thu Dec 07, 2017 3:02 pm
Jimny's also have it, but there has to be a way, i'd say..
Remove driver switch and replace it with the passenger switch... The switch is where it tells it what to do
The switch has like a step effect on the driver but not the passenger one,so i'd just say replace the switch
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by Darrell » Thu Dec 07, 2017 10:06 pm
I believe this is governed by the switch internal electronics. When the switch is held down for a pre-set time it will continue to lower the window until it mechanically stops/runs out of travel. I assume the current increase then switches the power off. This would be very difficult to replicate for the passenger window.
ipbr21054
Post by ipbr21054 » Fri Dec 08, 2017 10:23 pm
Hi
Yes you are correct.
All windows are electric.
Drivers is auto.
If you hold down drivers switch for say two seconds you can then let go and the window will go all the way down on its own.
Tomorrow I will swap them over and test.
Thanks.
ipbr21054
Post by ipbr21054 » Sat Dec 09, 2017 9:35 am
The switch that you see and operate is just cosmetic.
I mean I’ve just taken it all apart and the actual switch is soldered to the circuit board.
It’s not like your normal car where you unplug a loom from a switch to then plug in another switch to try.
Thanks anyway.
