Power window failure
liamo777
Post by liamo777 » Tue Jun 09, 2020 1:44 pm
Hi - any advice or tips much appreciated! I own a 2015 Vitara 1.6 DDiS Allgrip and out of the blue the power windows have stopped working. It started with a faulty passenger side window which then spread to the remaining windows. Checked the fuses and they appear to be fine?
Thank you
Liam
Re: Power window failure
Post by ScottieJ » Tue Jun 09, 2020 11:35 pm
I would check that you have 12v to the switches and that they are working next, it's going to be one of 3 things, a damages wiring loom (common place is where it feeds into the door), A dodgy switch or the motor. As its both sides I would say it's most likely to be a switch or wiring.
