Samurai 1298 & 1324 engine differences ?
Robert.m
Post by Robert.m » Mon Jul 20, 2020 8:35 pm
Hello, I've got my Samurai engine out to fix some oil leaks and I'm having problems getting parts from my local Motor Factor, mine is a G13BA (1298) and was wondering what apart from the obvious CC's is the difference with the 1324 engine.
I'm changing F & R crank seals, cam seal, timing belt, fan belt, clutch, RC gasket.
Is the Parts Book on this forum for 1298 or 1324 or both ?
Also out of interest if they are basically the same motor is the 1324 bigger bore or longer stroke?
Sorry if this has been asked before.
Re: Samurai 1298 & 1324 engine differences ?
Post by ScottieJ » Thu Jul 23, 2020 8:19 pm
1324 is basically just a stroked 1298, All seals, gaskets, belts, bearings etc are the same.
Robert.m
Post by Robert.m » Sat Jul 25, 2020 1:54 pm
Thanks Scottie, I've sorted all the oil leaks and currently putting the engine back in.
