Vitara inner track rod end
Alexcf119
Post by Alexcf119 » Sun Oct 22, 2023 7:42 pm
Hi, was wondering if it is possible to replace inner track rod end on 2018 Vitara without special tool and just jacked up
Re: Vitara inner track rod end
Post by ScottieJ » Tue Oct 24, 2023 10:13 am
You should be able to yes. Just make sure you get the tracking done afterwards.
I would also usually do the outer while it’s apart as well.
Alexcf119
Post by Alexcf119 » Sat Nov 04, 2023 6:52 pm
Discovered it was steering rack which was worn so replaced, was told quite common on vitara’s, has anyone else had same problem
