2009 jimny 4x4 selection problem
MAYFAIR
Post by MAYFAIR » Wed Apr 02, 2025 2:00 pm
Hello
2009 Jimny manual
have just fitted new suzuki vacuum pipes ( what a job) connect all vacuum pipes I can hear hubs clicking but wont
move from 4 low on dash - the original fault I had was not moving out of 4 low ,the vacuum metal pipes were all rotten
and crumbling at the front
the 2wd switch does not seem to operate, when the switch for 4wd is pressed the hubs are trying to click in quite loudly
i am sure i have the vacuum pipes on the way they came off - cannot seem to figure this one out as never had to do this job before
can anyone offer advice on this
many thanks Alan
Re: 2009 jimny 4x4 selection problem
Post by ScottieJ » Wed Apr 02, 2025 3:48 pm
Try reversing for 20m+ or so before shifting back into 2wd. It could just be a bit of transmission wind up in the transfer box.
MAYFAIR
Post by MAYFAIR » Wed Apr 02, 2025 4:37 pm
hi
just tried what you suggested ,but still the same - when comes out of 4 low should it show 4H on the dash ?
the 2wd has never lit up , as mentioned before i can hear the hubs on the front activating - what should it show on the dash when goes into 2wd ?
could it be the relays under the dashboard - never worked on the 4wd on a jimny before that has electric opp hubs so a little bit a "new starter"
cheers Al
MAYFAIR
Post by MAYFAIR » Thu Apr 03, 2025 9:29 am
Hello again
managed to crawl under transfer box and noticed a wire off the sensor on top of case - ordered a new one so hope that
sorts the select fault - has 2 wires to it one age corroded and parted from the switch
will update when fitted
Al
