carb su adaptor fab.
liljitjit
Post by liljitjit » Sun Dec 27, 2009 1:57 pm
Hi all just a quick one, a while ago i made up an adapter for my su carb and basically it was ok ish but i want to re do it as its to tall and ices up . I used a bent tube the first time round but was thinking of a straight tube(with a water heated jacket) this time just cut at the ends to give the appropriate angle for the two plates if you see what i mean, would this work the same way or do you have to have a bend? I cant see it making a differance as it will still be mounted in the side draught position, any thoughts guys ? All the ones ive seen fabricated are 90 degree bend type affairs.Pics of yours would be nice !
Thanks
rich
[/color]before you laugh at mine , take a look at your own![/color]
liljitjit
Re: carb su adaptor fab.
Post by liljitjit » Fri Jan 01, 2010 10:52 am
happy new year ! bump
bump :mrgreen:
Post by ScottieJ » Fri Jan 01, 2010 8:51 pm
I cant see it making much of a difference really, guess there's only one way to find out! :mrgreen:
liljitjit
Post by liljitjit » Mon Jan 04, 2010 9:32 pm
your right scott just a bit to cold here in stoke the garage is freeeeeeeeeezing! :cry:
will let you know how i get on soon as it warms up a bit.
chan
Post by chan » Wed Jan 06, 2010 2:06 am
sounds like a nice little project there mate! do you know why the sjs inlet manifolds are so prone to ice?
is a hot air feed from the exhaust good enough?
thanks
