had a wicked day out green laning on sunday and my car did absoulty great and was running perfectly all day!
i was about 1 and a half miles from home when i was going up a slight hill and it started juddering loosing power and juddering so i pulled over checked under the bonnet everything seemed fine and started her up and she went another half a mile and then died completely doing the same thing before. and wouldnt start after that.
the fuel gauge reads half a tank so im assuming its got fuel.
im pretty sure its the fuel lines blocked and the filter as it hasnt been on the road for a few months and all the bumps yesterday made the all the sediment stir up and block the filter ect.
i will take off the fuel pipe between the fuel pump and the carb and then turn the engine over to see if i get any fuel through that should determine if its the carb or not right?
and then take the pipe off between the fuel pump and the fuel filter in the now very muddy place rear wheel arch
i will get some new fuel filters to put inline.
one between the fuel pump and carb.
one between the fuel pump and solid lines on the chassis rail in the engine bay
one between the tank and solid lines.
any other ideas?
its an sj410 1990
when you turn the engine over it just doesnt start. i havent checked for spark yet but will do that first thing.
thanks alot in advance
