car help
grant
car help
Post by grant » Thu May 13, 2010 4:20 pm
hi can sum one help i have a grand vitara my 4 wheel drive back go round the frount are still the car is 2002 td
Re: car help
Post by ScottieJ » Thu May 13, 2010 4:58 pm
i'm not to clued up on grand vitaras but do you know if it has any kind of freewheeling hubs equipped to the front, you get manual, auto and air operated ones on grand vitaras throughout the years. if you have then they might either need to be locked or they are not locking automatically? Could you give us the year and model to help us out a bit more.
how did you notice, was it when it was jacked up off the floor? If it was and it has automatic free wheeling hubs that might be why the dont appear to be locked as i would presume they need to be on the ground and moving to lock themselves so drive a few metres in 4wd first and then check.
If it has air operated ones then there could be an air leak or the actuator within the front diff housing could be faulty?
Scottiej
Re: car help
Post by Tramp » Thu May 13, 2010 7:00 pm
Our lasses 03 grand vitara lwb, has permenant 4wd, so you can go to 4wd high to 4wd low and locked (i imagine a center difflock)
Luke
grant
Re: car help
Post by grant » Thu May 13, 2010 8:17 pm
scottiej410 wrote:i'm not to clued up on grand vitaras but do you know if it has any kind of freewheeling hubs equipped to the front, you get manual, auto and air operated ones on grand vitaras throughout the years. if you have then they might either need to be locked or they are not locking automatically? Could you give us the year and model to help us out a bit more.
Scottiej
dominic
Re: car help
Post by dominic » Thu May 13, 2010 8:18 pm
Hiya,
your having a problem getting back to 2wd from 4wd ?
Dom
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
grant
help
Post by grant » Fri May 14, 2010 4:03 pm
hi have vitara when i put in 4 wheel drive no llight on dash no frout drive :idea: :idea:the car is 2002 td
Re: car help
Post by ScottieJ » Fri May 14, 2010 4:39 pm
what year is your grand vitara? I have noticed that you say you are not getting a 4wd light when you switch it to 4wd however that might not actually be related to the problem. we do really need to know what year your vehicle is to work out what the problem might be.
My bet is on the air activated free wheeling hubs if it has them?
grant
Re: car help
Post by grant » Sat May 15, 2010 4:10 pm
scottiej410 wrote:what year is your grand vitara? I have noticed that you say you are not getting a 4wd light when you switch it to 4wd however that might not actually be related to the problem. we do really need to know what year your vehicle is to work out what the problem might be.
grant
Re: car help
Post by grant » Sat May 15, 2010 4:18 pm
hi the car 2002 how can i test the transfer 4 wd switch
dominic
Re: car help
Post by dominic » Tue May 18, 2010 8:44 pm
I cant help much as i only got my GV TD a couple of months ago, and im trying to find out as much as i can about them myself.
Your best bet is to go to http://www.suzuki4u.co.uk, and check out the forums there. this site covers every suzuki motor built.
Dom
8-)
Currently Drive
