Bearings bearings and more bearings +some other useful parts
Post by ScottieJ » Mon Oct 04, 2010 1:51 pm
Bear with me on this one while I compile all the bearing info (+ other related bits) on sjs you'll ever need :mrgreen:
SJ Transfer Box
Gasket part numbers –
(Bought from main dealer)
Main Case - U29525A80050 x1
Front Case – U29535_80050 x1
Seal Part number/sizes –
38x50x8_TC R23 NBR x1 http://simplybearings.co.uk/shop/advanc ... 8&x=38&y=8
OS38x60x08 x2 http://www.bearingboys.co.uk/search.cgi ... 08&x=9&y=8
Bearing sizes –
6306 NR circlip grooved x1 http://simplybearings.co.uk/shop/advanc ... rds=6306NR
22x56x16 63-22X_NSL x1 http://simplybearings.co.uk/shop/advanc ... ords=63/22
28x58x16 62-28 2RS x3 http://simplybearings.co.uk/shop/advanc ... ds=62%2F28
bearings sizes recognised by all bearing supliers.
King pin bearings
15x42x14.25 metric taper roller bearing 30302
rear wheel bearings
Rear wheel bearing part numbers for all sjs and samurais
Suzuki part numbers
Bearing 09269-35009 (bearing code DG357222DW)
Bearing retainer 43485-73000
Oil seal 09283-48007
Spacer (not needed if bearing above is used) 43429-77201
From bearing supplier
Bearing 6207-2RS (you may need a 4mm spacer ^^^^)
Oil seal is 48x62x8
From motor factors:
SKF Kit = VKBA1972
UJs
84 Onwards Jap built 25.00x63.80 code= PUJ2028 or Hardy Spicer greasable UJs HS157
SJ410 Flywheel Spigot bearing
6200 2RSH (2 rubber seals)
