vac pipe
vac pipe
Post by ROBBIE » Fri Oct 22, 2010 7:47 pm
can anyone tell me where this pipe goes. its on a 1.6 standard carb, is it important?
the 1 with the red line
i know an su would be better but i aint got 1 or the money
cheers
rob
Re: vac pipe
Post by ScottieJ » Fri Oct 22, 2010 8:37 pm
I'm not 100% sure but it might go to one of the 3 vacuum points on the inlet manifold pretty much underneath where it is. However I might be wrong as its part of the idle up system and I completely removed all that on mine so I can't remember.
It's not that important all it does it pick up the revs when you turn on the lights or heaters. If you do take it all off just bridge the two left over back points with a bit of the tube.
Scott
Re: vac pipe
Post by ROBBIE » Fri Oct 22, 2010 9:32 pm
cheers scott it goes to the purple bsv, i think its called mine fell to pieces and after much fidling about i was left with pipes everywhere most of which were obvious but i wasnt sure about this 1 so just thought id ask to make sure i wasnt blocking some thing important
rob
Henry
Re: vac pipe
Post by Henry » Sat Oct 23, 2010 12:26 am
That round thing looks like the advance from the distributor...
Re: vac pipe
Post by ROBBIE » Sat Oct 23, 2010 10:59 am
henry-the-hoover wrote:That round thing looks like the advance from the distributor...
same thing. it ups tick over when you use electrics, lights, wipers, heater
Re: vac pipe
Post by Tramp » Sat Oct 23, 2010 12:15 pm
Its not... I think he means the vaccum advance which alters the engine 'spark' timing as the engine rpms increase, but I don't know, i thought the vac advance came from the inlet manifold?
Re: vac pipe
Post by ROBBIE » Sat Oct 23, 2010 2:35 pm
sorry i meant its a vac on the carb which controls the throttle butterfly, i was led to believe by suzuki main dealer thats what it was for.
the vac on the dissy is connected on the engine side of the carb
hope that makes sense :mrgreen:
ferris
Re: vac pipe
Post by ferris » Sat Oct 23, 2010 6:31 pm
Heres what mine looks like. It hasn't got a pipe on it, it just has a piece of what looks like cotton wool stuck in the end.
