help with fitting a turbo on a sj413
farmerben
Post by farmerben » Wed Nov 17, 2010 7:45 pm
hi,
i was thinking of fitting a turbo on my 1990 sj413 but wondered how much boost the engine would take ,and where to take the turbo oil feed from and where to put the oil return ????
many thanks,ben 8-)
1992 Suzuki SJ 413 samurai,TURBO,Webber carb,2" calmini shackle reversal kit,32mm wheel spacers,maxxis 235/75/15 mud tires,vitara alloys,swift gti interior,1"lift springs,heavy duty transfer box mounting bracket.
1986 land rover 110 ,boost alloys,bfgoodrich mud terrains,a bar,spot lights,
Re: help with fitting a turbo on a sj413
Post by Edweird » Sat Nov 20, 2010 7:02 pm
I don't know much myself, but this popped up on my yotube recommended today and I remembered your thread.
http://www.youtube.com/watch?v=JEAvEPgu ... grec_index
He might be worth talking to, if you can message him through youtube. According to his video, he's using 25psi boost.
Post by ScottieJ » Sat Nov 20, 2010 9:55 pm
That engine must've had some serious work done to the internals then as a stock sj lump's limit would more than likely be around 6-8psi. anything more and I doubt the bottom end would last long. I would imagine the Sammy in the vid was running a modded swift gti lump.
I personally think if you want to off-road your Sammy then you'd be better off fitting a 1.6 vit lump or fitting a supercharger as you want torque not high rev bhp.
If you are serious about turboing it then your best bet would be to look on teamswift.net as not many sj owners bother turboing them.
Henry
Post by Henry » Sun Nov 21, 2010 7:02 pm
Mate of mine fitted a 306 turbo to his 1.3 (engine was on its way out)
It went well, but just sped up the process of dying... from about 6 weeks to 6 days :twisted:
Long story short, its not worth it, fit a tdi lump in it instead :twisted:
farmerben
Post by farmerben » Wed Dec 08, 2010 8:35 pm
thanks for the help people !
farmerben
Post by farmerben » Tue Jan 18, 2011 10:20 pm
ive borght a garrett t15 turbo and have started making a manifold ! does anyone know the size of the oil pressure switch thread as i need toget a t-peice ? is it 1/8npt?
garrett t15
garrett t15
DSC_0315 [1600x1200].jpg (14.37 KiB) Viewed 14119 times
turbo manifold plate
DSC_0325 [1600x1200].jpg (17.82 KiB) Viewed 14117 times
Post by twiss » Wed Jan 19, 2011 10:59 am
think so yeah...
farmerben
Post by farmerben » Tue Mar 01, 2011 9:45 pm
hi this is how far i am at the moment i was just wondering would it be ok to run the oil drain from the turbo into the rocker cover???
manifold fully welded
DSC_0398 [50%].jpg (150.11 KiB) Viewed 14048 times
oil pressure tee piece
DSC_0399 [50%].jpg (113.65 KiB) Viewed 14048 times
all bolted up
all bolted up
DSC_0402 [50%].jpg (99.21 KiB) Viewed 14048 times
farmerben
Post by farmerben » Thu Mar 10, 2011 9:33 pm
hi people i had it running the other day just got to sort out the air filter and exhaust and will most probably need some fine tuning but,here is a link to see/hear it running as it is at the moment let me know what you think
Click Here for Youtube Video
turbo fitted !
turbo fitted !
DSC_0423 [50%].jpg (115.33 KiB) Viewed 14022 times
turbo fitted !
turbo fitted !
DSC_0422 [50%].jpg (130.02 KiB) Viewed 14022 times
oil return pipe welded into sump
DSC_0420 [50%].jpg (127.47 KiB) Viewed 14022 times
manifold sand blasted and light coating of heat proof paint
DSC_0411 [50%].jpg (204.4 KiB) Viewed 14022 times
Post by ScottieJ » Thu Mar 10, 2011 9:53 pm
sounds good, bet you cant wait to see how much power you have now :guns: so hows the paint on the chassis :lol:
what psi are you running?
