Running on three with blue smoke
SimonSam
Post by SimonSam » Sun Dec 05, 2010 12:37 pm
I have recently changed the engine like for like 413 -413 and at first had problems getting it running which turned out to be dodgy dizzy. Anyway it now starts and runs but only on three cylinders despite a spark. The spark plug is a bit wet but doesn't really smell of petrol so thought maybe headgakset but theres no water were it shouldn't be and the system isnt pressurizing. There is a constant blue smoke which isn't horrific but not great. Any ideas? My dad thinks could possible be a dodgy valve? Anyone got any ideas? Seems i'm not havng much luck so far and if this engine has had it then there will be an Samurai up for sale :argh:
Pugsley
Re: Running on three with blue smoke
Post by Pugsley » Sun Dec 05, 2010 11:29 pm
Looks like you need to do a compression test on the dodgy cylinder. You have a spark, you seem to have fuel and I assume you have air - the missing element would appear to be lack of compression.
SimonSam
Post by SimonSam » Mon Dec 06, 2010 3:33 pm
Yep already ordered a compression tester so will do that when it arrives, dreading the result to be honest. :cry:
Post by ScottieJ » Mon Dec 06, 2010 4:07 pm
well plue smoke is a sign that your burning oil so yes could be a dodgy/sticking valve with a leaking stem oil seal or it could be the piston rings on that cylinder?
SimonSam
Post by SimonSam » Mon Dec 06, 2010 4:14 pm
:cry:
Need it to be something simple(ish) or this SJ project of mine could well be very short lived.
Post by ScottieJ » Tue Dec 07, 2010 12:28 pm
the valves are an easy and cheap fix. head off job. the piston rings aren't that bad a job either. What was wrong with the last engine? can you not make a good one out of both?
