Starters for sj 1.6 conversion
Post by twiss » Wed Dec 08, 2010 11:05 pm
Always double check that the motor diameter is around 3", that fat 3.25" ones need grinding
Bosch skinny starter part number 0-001-112-032
Mitsubishi skinny starter m1t74583
DRS3045 This is a generic part number so it might take a few attempts before your local parts store gets a skinny one using it
QS1430
Alternatives.
Bear with me on this one, I want to double/triple check it's the right part number
I found this on my mates jap SJ 413 ...
it fits properly on a samurai gearbox as well.
Smaller than the skinny starters that are getting quite rare now...
Valeo D6RA13
This is the starter I originally started off with.
Get them new from here: http://www.woodauto.com/Unit.aspx?Man=VALEO&Ref=D6RA13
It looks very similar to the D6RA62, but can be told apart from it due to the different size housing although the motor itself and the solenoid are the same.
This starter had 9 teeth and will fit on a Suzuki.
You can see in the photos below how similar they are. The first photo shows my D6RA13 with the D6RA62 motor and solenoid.
The second picture shows the housing parts of both starters and how they differ.
D6RA62 housing on the left, D6RA13 housing on the right
D6RA62
This is fitted to quite a few different cars, so is easy to come by.
You do need to check the amount of teeth on the gear though, as some have 9 and some have 10.
They are fitted to:
OPEL Agila 1.2 01/2000 -
OPEL Astra F 1.4i 09/1991 01/1998
OPEL Astra F 1.6i 09/1991 01/1998
OPEL Astra G 1.2 16V 03/1998 -
OPEL Astra G 1.4 16V 03/1998 -
OPEL Astra G 1.6 16V 03/1998 -
OPEL Astra G 1.6 8V 03/1998 -
OPEL Corsa B 1.2 02/1993 01/2000
OPEL Corsa B 1.4 03/1993 01/2000
OPEL Corsa B 1.6 03/1993 01/2000
OPEL Corsa B 1.6i 16V 11/1994 01/2000
OPEL Corsa C 1.2 04/2000 -
OPEL Corsa C 1.4 16V 04/2000 -
OPEL Vectra A 1.4 09/1988 01/1994
OPEL Vectra A 1.6 01/1994 01/1995
OPEL Vectra B 1.6 16V 09/1995 -
OPEL Zafira 1.6 16V 03/1998 -
VAUXHALL Cavalier 09/1988 01/1994
There is another starter than basically shares all of the same components, except for the silver metal casing. The motor, solenoid and gears are the same.
These are normally about £30
I haven't tried it but you can get remanufactured cavalier one for £30!
:shock:
http://cgi.ebay.co.uk/S715-VAUXHALL-NOV ... 5d2afd9dbb
D6RA 63
Ideally you need to get a starter that is a D6RA13 to begin with, but these have the correct amount of teeth and are good for spares.
They are fitted to:
RENAULT Laguna 2.0 16V 09/1999 01/2001
VOLVO S40 1.6 01/1997 -
VOLVO S40 1.8 09/1995 -
VOLVO S40 1.9 T4 05/1997 01/2000
VOLVO S40 2.0 01/1996
You can get them on Ebay for £40 roughly... cheaper from a motor factors or scrappy where you don't have to pay for delivery.
The good news is, if you find a cheap one with 10 teeth, you can get the gear for just under £15 and swap it
http://www.woodauto.com/Component.aspx?Ref=SDV38156
Easiest way to find them is on ebay, i.e. search for "vauxhall cavalier starter motor"
Re: Alternative starter for sj 1.6 conversion
Post by twiss » Wed Dec 08, 2010 11:06 pm
Oh my god this forum is way better than Difflock, I can sticky my own stuff ;)
Russ24
Post by Russ24 » Thu Dec 09, 2010 12:46 am
twiss wrote:Oh my god this forum is way better than Difflock, I can sticky my own stuff ;)
muhahaaa!
specified SJ requirments
and holy crap at the universal opel starter :)
:russ:
Post by ScottieJ » Thu Dec 09, 2010 8:54 am
We do our best :mrgreen: and this is worthy of a sticky so we'll keep it as one.
Good bit of info there twiss :mrgreen:
Post by twiss » Thu Dec 09, 2010 9:10 am
I've had the starter on there for over 2 years now, and it's only broken cos I went to flipping Slindon!!!
Ordered another for £25 though :mrgreen:
Post by Edweird » Thu Dec 09, 2010 7:44 pm
Russ24 wrote: and holy crap at the universal opel starter :)
Hehehe, my Dad'll probably have a dozen or two if they fit that many Vauxhalls/Opels. He has his own private parts emporium. :lol:
muddy kev
Post by muddy kev » Thu Dec 09, 2010 9:23 pm
i've killed lots of alternators at slindon. but u have 2 go through the bomb hole.... u just have to!!!!
Post by twiss » Thu Dec 09, 2010 9:39 pm
I'm not gonna go there again... always break stuff at Slindon, never break stuff anywhere else! :argh:
(Except my throttle cable but who cares about that?)
muddy kev
Post by muddy kev » Sun Dec 12, 2010 8:37 pm
piccadilly wood my most expensive site. 1 leaf spring, 1 drive shaft, 1 starter and lots of dents :lol: :lol:
although slindon is the only site i've managed to get it on its roof !!!
Russ24
Post by Russ24 » Tue Dec 14, 2010 8:42 pm
twiss wrote:I'm not gonna go there again... always break stuff at Slindon, never break stuff anywhere else! :argh:
yup .. slindon that day... was erm.. a 'killer'
the crawley 4x4 club suffered heavey loses at the hands of slindon.... (mostly landys i might add) front end on a disco 2, diffs on, a defender 90 (both front n rear) diff on another disco... TWISS aswell... alternator :p a vauxhall fronteiraa clutch and what happened to my wheel bearings and erm... something...
i once killed a car soo good there, (acidentally jumped it 3ft) that it now resides in my shed as spares. however i sold the engine...(twas nackered mind) which somehow ennded up in slough... which is IN the car i bought yesterday... small world ey?
weird dot com.
:russ:
