Tolerances
Tolerances
Post by ScottieJ » Tue Jul 05, 2011 12:33 pm
I was working on the front samurai axle for my sj yesterday, mounting all the spring hangers etc. and I was there for ages trying to get everything as spot on as possible and in the right positions.
But while I was doing all that it got me thinking what are the actual tolerances that companies like Suzuki use on their chassis/suspension etc. I'm guessing they aren't actually that tight as you have the movement in the rubber bushes, shackles etc. so what's a few mm difference going to make.
Does anyone know what tolerances they work to from the factory?
I know that caster angle is obviously important and needs to be around 3-5 degrees but what about everything else?
Henry
Re: Tolerances
Post by Henry » Tue Jul 05, 2011 9:00 pm
Surprising how you can move things around when you tighten bolts up.
But i wouldnt have thought it would be over 3-5mm. But scott, do it spot on, you will make your own tolerances, your human :lol:
