automatic gearbox
clunkychunky
automatic gearbox
Post by clunkychunky » Tue Jul 05, 2011 8:30 pm
looking for suggestions for automatic gearbox options for sami.
easily obtainable conversions of much cheapness
you can't polish a turd
Re: automatic gearbox
Post by turbo-tom » Tue Jul 05, 2011 9:55 pm
would you be able to mod a auto vitara box ? and match it up to the same vit engine etc ? :S :P
Post by twiss » Wed Jul 06, 2011 9:38 am
That's a good idea tom, surely the vit auto gearboxes can't be that much different in size and shape to the manual ones...
I doubt they would have different gearbox mounts on the chassis for the autos...
Any ideas scott? Being the one with the vitara gearbox :P
Post by ScottieJ » Wed Jul 06, 2011 10:32 am
The answer is Yes you can do it but it requires quite a bit of work, widening the transmission tunnel and other fabrication etc. Earlier vitaras had quite a simple auto (o3-72LE) that has no electrics to piss around with that you can use.
you need to modify the vitara gearbox to mate up to an sj tbox as well.
have a read here (uses a kit available in the US though)
and here is Baloos take on fitting a vit auto into an SJ; I'm not even sure if baloo ever got it finished though????
remove vit transfer case from gearbox
remove all the black bolts from the tcase to take of the front section
pull this bearing and shaft out and replace with a bearing of the same outer diameter (72mm) but with a smaller internal diameter (32mm I think)
you also need to swap the oil seal for one that fits the sj to transfer box prop.
make a blanking plate out of 4mm steel/ally
You'll need to shorten the intermediate prop as well as modify the gearbox crossmember to sit the gearbox lower.
If it was me I would raise the tbox to help line it all up and to give you a flat bottom :thumbup:
