Mounting harnesess in pick up cab
implainlazy
Post by implainlazy » Sun Jul 10, 2011 1:49 pm
Looking to mount harnesess into my sj at some point, along with the pick up conversion. Has anyone managed to mount 4 point harnesess into pick up cabs, without putting the straps through the rear bulkhead?
At the moment, i'm thinking about trying to find a "harness bar", which i could attach across from the top seat belt mounts, run the harnesess over them, and down 90 degrees to the floor mounts. Not sure if that would work or not :|.
Re: Mounting harnesess in pick up cab
Post by Edweird » Sun Jul 10, 2011 4:41 pm
Sounds reasonable. I've seen what you're describing in old rally cars. It's a harness, so it won't matter where it's attatched so long as you can get it tight and it won't go slack.
implainlazy
Post by implainlazy » Sun Jul 10, 2011 6:06 pm
Yeah, I've heard that the angles and stuff have got to be a specific angle, otherwise they can cause spinal damage in a collision =\. to be honest though, if it's over a harness bar, there wouldn't be any downward force on the spine as the harness bar would change the direction of force? (if that makes sense??)
