transfer box stuck in neutral
mayhemmiller
Post by mayhemmiller » Sun Oct 02, 2011 1:12 pm
so what a night last night went to get take away with some friends were sat in tesco car park when a friend as what the 2'nd gear leaver does i explain it's to put the car in 4wd
she then push the leaver through 4wd high to low as she pulls it back through neutral it then lock rock solid (the engine was off )
i tried rolling it back and forth and still couldn't get it to engage
4 hours latter i arrive home with it on the back of a lorry
and thoughts before i take it off and strip it down
awaiting the next adventure
:mayhemmiller:
dunk
Recommended Trader
Recommended Trader
Re: transfer box stuck in neutral
Post by dunk » Sun Oct 02, 2011 4:41 pm
It may be the shift sheet under the t box lever. If its worn it's hard to shift gears. If it is worn and you don't have another one we sell a polly one at Muddyzook. http://www.muddyzook.com/" onclick="window.open(this.href);return false;
mayhemmiller
Post by mayhemmiller » Mon Oct 03, 2011 7:26 pm
well striped out the top end today and look like your right took out the rubber seal then it went into 2wd so look's like i need a new one do you think i can still drive it with out one ?
:mayhemmiller:
dunk
Recommended Trader
Recommended Trader
Post by dunk » Mon Oct 03, 2011 8:20 pm
You can still drive it but as you know it's a pain to shift the t box.
mayhemmiller
Post by mayhemmiller » Tue Oct 04, 2011 6:26 pm
i only plan on using it on the road until i get it fixed
:mayhemmiller:
