getting fuel out
leebob
getting fuel out
Post by leebob » Fri Nov 11, 2011 5:19 pm
hi all is there a fuel drain on an 83 sj or can i syphon fuel out the filler neck? got full tank but need to get the tank out.
Re: getting fuel out
Post by ScottieJ » Fri Nov 11, 2011 9:19 pm
Some have a drain others don't, there should be a hole in the bottom of the guard where it is if there is and you can syphon the tank easily if there isn't.
Post by turbo-tom » Fri Nov 11, 2011 9:20 pm
mine didnt so i pulled both the pipes of the carb put one pipe in a container and shuved compressed air down down the either and it comes out phucking quick too :lol:
Post by twiss » Mon Nov 14, 2011 9:29 am
^ That's quite a good idea...
Good for if you accidentally put diesel in or something, take off your fuel hose and piss the fuel out all over the petrol station forecourt ;)
Post by dan_2k_uk » Mon Nov 14, 2011 10:10 am
I pull the carb feed off mine and it runs long enough to pump over a litre into a bottle on the contents of the float chamber on the su! Good if you need to get some out for offroad bbq/fire lighting :guns:
