LJ80 DISTRIBUTOR
pro4x4@hotmail.com
LJ80 DISTRIBUTOR
Post by pro4x4@hotmail.com » Thu Dec 08, 2011 9:44 pm
Anyone know if 1300 and 800cc dizzies are interchangeable??
Re: LJ80 DISTRIBUTOR
Post by ScottieJ » Thu Dec 08, 2011 10:02 pm
As far as I.m aware you need a 1.3 dizzy and coil, 1.3 coil doesn't have a ballast resistor like the 800cc
You also have to take account of the fact the 1.3 dizzy has vac advance but there is no vacuum take off on the carb on the 800. There are a few ways around that though, fitting stronger springs to the mechanical advance system etc or making a vac take off point.
Post by ScottieJ » Fri Dec 09, 2011 1:00 pm
Wring for you and another note: make sure that you get a dizzy from a carb'd SJ413 the later SPI dizzy's won't work.
This should help
