413 engine and gearbox change - as one
timpaton
Post by timpaton » Mon Dec 12, 2011 4:11 pm
Hi,
I have established that i have a top end death rattle, and the gearbox is just as bad.
I have got hold of a replacement engine and box as one piece.
Question - can this be fitted as one from underneath with a trolley jack, or is it from above with an engine crane job?
Re: 413 engine and gearbox change - as one
Post by ScottieJ » Mon Dec 12, 2011 4:17 pm
easiest way if you are pulling both is to use a crane and pull it out through the engine bay. You can remove the whole front end in about 20/30 minutes and that make it easier.
timpaton
Post by timpaton » Mon Dec 12, 2011 4:22 pm
Many thanks, I will go and hire an engine crane this weekend
Post by twiss » Mon Dec 12, 2011 4:32 pm
I personally would split the box and the engine...
I don't think it takes much longer than 30 minutes to drop the gearbox out? :)
Post by ScottieJ » Mon Dec 12, 2011 4:40 pm
If you've got a hoist it's easier all in one unit I think. Where are you in the country? might be a member close by who is will ing to lend you one???
Post by twiss » Mon Dec 12, 2011 4:43 pm
That depends on the hoist and the lift ;)
It would have taken a miracle to hoist the engine and box into Russ' SJ with its 8" lift haha
I guess it would be much easier with one of those spreader bar things to level it out
Post by ScottieJ » Mon Dec 12, 2011 4:48 pm
you shoulda seen my dad and I pulling my engine and transmission out with the front clip still on in one unit then :hahaha:
Just to give Tim an Idea of what I mean
This is my engine and transmission
Post by twiss » Mon Dec 12, 2011 4:49 pm
What's that fugly range rover doing there?
Post by ScottieJ » Mon Dec 12, 2011 4:53 pm
twiss wrote:What's that fugly range rover doing there?
That's my old workshop it's my housemates and I often ask the same myself, it's not moved in about 2 years :lol:
Henry
Post by Henry » Mon Dec 12, 2011 5:52 pm
Id go for complete unit, just remember you need a lot oh height to get the box out, like scot said the front can come off but you may be easier without, just you will need 2 people to stop it coming forward and smashing sh1t out of the front.
If your near me i can help
