x9 winch...
x9 winch...
Post by turbo-tom » Wed Dec 21, 2011 11:21 pm
its oldish , never had any trouble with it :D , but going to move the plast solinod box thing ,
and unsure what cable to use ? , what voltage do you lads recommend ?
i was thinking maybe like decent battery cable or something ?
i was think about using a 600amp rated cable or is that about overkill ? :er:
cheers tom :rockin:
Re: x9 winch...
Post by turbo-tom » Thu Dec 22, 2011 11:23 pm
anyone ? :lol:
Re: x9 winch...
Post by dan_2k_uk » Thu Dec 22, 2011 11:34 pm
Depends on the rating of the winch.
Does it have a data plate on it?
Re: x9 winch...
Post by turbo-tom » Thu Dec 22, 2011 11:43 pm
all i know its a standard x9 i belive ? , all i really want to do is just move the soilnod box into a better location :lol:
Re: x9 winch...
Post by turbo-tom » Thu Dec 22, 2011 11:46 pm
says this
Line Pull: 0 lbs 73 Amps Motor Draw / 38.2 FPM (11.6 MPM) Line Speed
Line Pull: 9,000 lbs 420 Amps Motor Draw / 2.5 FPM (0.8 MPM) Line Speed
on here http://www.superwinch.com/products/prod ... .0.0?pp=12&" onclick="window.open(this.href);return false;
only sixteen im all new to electrics :oops: :oops: :D
dantheman6106
Re: x9 winch...
Post by dantheman6106 » Fri Dec 23, 2011 9:37 am
You wanna use 35mm battery cable to be safe and you will also need some crimp on Lug terminals for each end, I got all my stuff from Goodwinch, was about £6 per m
Dan
Re: x9 winch...
Post by turbo-tom » Fri Dec 23, 2011 1:14 pm
but 35mm cable is only rated at 240 :er: :er:
chrisj410
Re: x9 winch...
Post by chrisj410 » Fri Dec 23, 2011 1:28 pm
I'd give David from goodwinch a ring, I've just bought a few of his products, very helpful guy. Delivers very quickly too if your in a rush
Re: x9 winch...
Post by turbo-tom » Fri Dec 23, 2011 2:42 pm
chrisj410 wrote:I'd give David from goodwinch a ring, I've just bought a few of his products, very helpful guy. Delivers very quickly too if your in a rush
cheers for that mate , emailed him and got a response striaghaway and he said used 35mm cable ;)
chrisj410
Re: x9 winch...
Post by chrisj410 » Fri Dec 23, 2011 4:05 pm
Sweet :) got some pics of your dials/gauges yet mate?
