what wire does what...
Post by turbo-tom » Fri Dec 23, 2011 12:20 am
got this in the drivers side wing near the headlamp , what do they all do :lol: , was just going to tape em all up
Henry
Re: what wire does what...
Post by Henry » Fri Dec 23, 2011 5:27 pm
Where do they come from?
Anything not working?
Post by ScottieJ » Fri Dec 23, 2011 5:56 pm
Was your SJ originally a 410?
If so the brown and black with yellow tracer used to be part of the ignition wiring for the ballast resistor.
Black with white tracer is an ignition live so you don't want that shorting out on anything
Yellow with white should be going to your alt? The plastic bit at the end is covering 1 half of a fusable link, the other half would then be connected to the + on the alt?
Post by turbo-tom » Fri Dec 23, 2011 7:05 pm
Henry wrote:Where do they come from?
believe everything works allright , there in the main wireiing loom :lol:
ScottieJ wrote:Was your SJ originally a 410?
nopee i think its beena 413 all its life :lol: :rockin: , coolio so as there work ill just shuv some tape around then ? , and ill take a pic of my altenator tomorrow ? :D
