Engine serial number
Post by Anton » Tue Jan 31, 2012 4:30 pm
Hey, people. Looking for the serial number on my SJ's replacement engine, and I can't seem to find any markings that look like a serial number. I need to declare the engine swap to the DVLA so I can get the V5 updated.
All I can find is a "1298CM3" marking on the exhaust side of the engine near the bellhousing, about half way up the block itself.
I've done a google search (and searched this and various other forums) and the best I can come up with is that it's supposed to be on the left of the block near where the engine connects to the gearbox. I assumed that meant exhaust side, near the bellhousing - roughly where mine says "1298CM3"...
It's (sort-of) snowing out, I still have a touch of flu, and I'm tired of crawling around under my truck looking for something in the shadows (my torch is on the fritz).
Help!
Re: Engine serial number
Post by ScottieJ » Tue Jan 31, 2012 4:43 pm
I'm pretty sure it's stamped on the flat machined section directly below where the capacity is i.e. the 1298CM3
Post by twiss » Tue Jan 31, 2012 4:55 pm
Yes it is stamped there, but I think the gearbox covers it up!!!
If it's a 1298 it's probably a G13BA engine.
I think the 1324cc is the G13A
The 1298cc is the G13BA
Post by ScottieJ » Tue Jan 31, 2012 4:58 pm
the gearbox shouldn't cover it up
it should be here
Highlander
Post by Highlander » Tue Jan 31, 2012 5:03 pm
Maybe its been ground off :brows:
Post by Edweird » Tue Jan 31, 2012 5:04 pm
Or it could be covered with swollen rust. My block looks like it's covered in tiny little brown flowers or something :S
Post by ScottieJ » Tue Jan 31, 2012 5:07 pm
Edweird wrote:Or it could be covered with swollen rust. My block looks like it's covered in tiny little brown flowers or something :S
your block is cast iron, ours are aluminium ;)
Post by Edweird » Tue Jan 31, 2012 5:11 pm
Oh, I thought that one in the picture had been painted
Post by twiss » Tue Jan 31, 2012 5:14 pm
That's odd, my 1600 8v definitely has the engine code on the back of the block.
So does the 1600 16v on my garage floor...
I guess the 1300s are different then
Edit: Ohhhhh serial number I see... I was going on about the model number!
Post by dan_2k_uk » Tue Jan 31, 2012 5:16 pm
Ive gotta go compare the G13 and G16's Ive got now.
BRB
