Rear disc conversion SJ413
Posted: Tue Feb 07, 2012 9:31 pm
by dunnin21
hi people, im looking into doing this conversion, i have seen some rover 800 calipers on the bay. Item number: 290667085261 it says on the listing that all i need are some standard sj front discs is this true, or do i need the mounting brackets i have seen on other post, this is my first SJ so any help would be much appreciated thanks Andy
Re: Rear disc conversion SJ413
Posted: Tue Feb 07, 2012 9:55 pm
by Henry
Hi Andy,
If you sj is a 413 it should have the t box handbrake fitted, in which case you can use front sj calipers and discs with a special mounting plate. I used muddyzook kit, it was good but in hind sight i should have painted the kit.
If you haven't got the T box handbrake you will need the 600/honda accord callipers, and the handbrake kit from muddyzook. For this kit you also need the twin handbrake cable set up. Hope this helps.
Posted: Wed Feb 08, 2012 9:27 am
by Newtomud
Hello and
to the club Andy.
I'm new to SJ's but this was the first thing I did to mine.. There are some pictures on my build thread which might be helpful?
I think there is also a write up in the diy section.
Let us know how you get on
Posted: Wed Feb 08, 2012 9:50 am
I'm probably doing rear disc conversion next weekend...
I think I will be using SJ calipers and fitting a 410 prop brake
That way you only have to carry around 1 type of brake pads
Posted: Wed Feb 08, 2012 10:48 am
by Highlander
I used ford Scorpio calipers that have the built in handbrake
Posted: Wed Feb 08, 2012 11:42 am
I dont suppose they fit on the standard SJ caliper mounts?
Posted: Wed Feb 08, 2012 3:12 pm
by Highlander
lol no
Posted: Wed Feb 08, 2012 8:32 pm
by dunnin21
ok thanks every one for the info
