Electric fuel pump
Electric fuel pump
Need a leccy fuel pump any reccomendations and it's for my 410
Chris
Chris
Re: Electric fuel pump
Hi Chris,
You want a low pressure facet fuel pump, they aren't very expensive... usuall around £30-40
This is pretty much the one that I am using
Click Here for Ebay Listing
- ianedwards
- SCUK Addict
See the thread a bit further down, loads of info from the guys in that. I asked the same thing.
Ian
Ian
Ian.
Ian.
that was for a samurai tho wasnt it?
cheers Twiss
cheers Twiss
All carb engines will run off a low pressure pump pretty much!
ahhh fair enough,
thanks twiss
thanks twiss
- ianedwards
- SCUK Addict
- justaddmud
- Can I have a tow
as a warning, on the solid state pumps like the one above, they are designed for pushing fuel as apposed to sucking so mount it close to the tank not in the engine bay.
- ianedwards
- SCUK Addict
hmmm interesting,
mine was in the engine bay,
do you think it would be a good idea to relocate my new one then. to sort of around the tank area.
cheers
Iab
cheers
Iab
Ian.
Ian.
- justaddmud
- Can I have a tow
might as well, plenty of room under there with the tank
only said it as a good friend of the family, who happens to run a parts shop and has built (and won in) several rally cars, he advised me that the pumps like that are no good at sucking fuel over a great distance, might be on the pickup that it was close enough not to matter where as on the normal SJ's the tank is as far away from the engine as can be
