Rear diff,
ianedwards
Rear diff,
Post by ianedwards » Wed Feb 22, 2012 5:43 pm
Hi, I've been sorting out my rear axle on 413, new brakes, bearings, and oil.
Main problem is the main input shaft seal is leaking oil since the change, as it defiantly wasn't before.
Any one got any ideas why this is.
Ian
Ian. :)
Re: Rear diff,
Post by dan_2k_uk » Wed Feb 22, 2012 6:22 pm
Thinner oil than the old stuff?
Highlander
Re: Rear diff,
Post by Highlander » Wed Feb 22, 2012 6:38 pm
More oil than it had before? :D
ianedwards
Re: Rear diff,
Post by ianedwards » Thu Feb 23, 2012 12:36 pm
i dont know, quite a lot came out, old and lumpy stuff. i filled it up the the hole, probably the seals gone and the new oil is coming out where the old stuff didnt.
dunno grrrrrrr
Ian. :)
Re: Rear diff,
Post by ScottieJ » Thu Feb 23, 2012 12:54 pm
sounds like the old stuff had just gone too thick to leak, i guess it was quite creamy looking because of water contamination?
you can swap the seal but really you need to fit a new crush collar as well. I would be inclined to replace the seal, crush collar and both pinion bearings.
ianedwards
Re: Rear diff,
Post by ianedwards » Thu Feb 23, 2012 2:50 pm
Bugger, takes a bit of setting up doesn't it.
Ian. :)
Re: Rear diff,
Post by ScottieJ » Thu Feb 23, 2012 4:28 pm
It's not that hard to swap the pinion bearings, ideally you do need a dial meter to set the backlash however if you carefully take note of how it comes apart, exact amount of turns to undo the carrier bearing tensioners etc. then you can do it without, my old rear diff was set up just by feel and I never had any problems with it.
here's a little guide http://www.rsmfg.co.uk/page17.html it is for replacing the standard crush collar with a solid one but it gives you a good idea.
Christoff
Re: Rear diff,
Post by Christoff » Thu Feb 23, 2012 5:25 pm
Breathers blocked?
Christoff
Re: Rear diff,
Post by Christoff » Thu Feb 23, 2012 5:31 pm
Just read the link posted by Scottie, how many people have locking diffs in their SJ's?
ianedwards
Re: Rear diff,
Post by ianedwards » Thu Feb 23, 2012 6:42 pm
ill check the breathers, im going to run some lines up to some ware. ill have a read.
Ian. :)
