Battery size
Rooge
Battery size
Post by Rooge » Thu Mar 08, 2012 6:49 pm
Hi
I'm going to fit a second battery to my sj to run winch and spot lights etc what size battery would I need amp wise??
Cheers :thumbup:
ianedwards
Re: Battery size
Post by ianedwards » Thu Mar 08, 2012 9:38 pm
Big lol
Ian. :)
Highlander
Re: Battery size
Post by Highlander » Fri Mar 09, 2012 9:39 am
Depends on your winch but the bigger the better
I'd go for something with at least 650 CCA (cold cranking Amps)
Rooge
Re: Battery size
Post by Rooge » Fri Mar 09, 2012 2:39 pm
Cool I looked at that numax 1000 as well, think I'll go for 1 of them!
Cheers lads :doublethumbs:
Re: Battery size
Post by ScottieJ » Fri Mar 09, 2012 6:09 pm
hugh42 wrote:When I was going to do this I researched it alot and was going to get a
Numax CXV-X 1000 Amp
Specifications
12V 86Ah
Cold Start Marine Cranking Amps: 1000A
Deep-cycle & Starting
Sealed Lead Acid
This will work well with that winch and costs about £88 delivered. Good luck!
That's what I'm getting for mine next, had the same Numax in my SJ since ive had it and it's taken a lot of abuse and survived to this day, however it is starting to get a bit tired now :lol: not really surprised though as I've lost count of the amount of times its been flattened over the years!
