lockright locker in both diffs?
Jamie_stafford
Post by Jamie_stafford » Tue Mar 13, 2012 9:16 am
Will the Suzuki SJ / Samurai Powertrax Lockright Differential Locker fit in the front and rear diffs in my samurai?
Suzuki, because life's to short to be fixing landrovers!
Highlander
Re: lockright locker in both diffs?
Post by Highlander » Tue Mar 13, 2012 9:33 am
I think it depends on the year/axle but must be possible I know one that has both fitted.
Jamie_stafford
Post by Jamie_stafford » Tue Mar 13, 2012 9:54 am
Mine a a j reg samurai tintop, if it helps? :-D
Highlander
Post by Highlander » Tue Mar 13, 2012 10:03 am
I've no idea but I know the guy that fitted the front one to his had to change axles for some reason to make it fit.
have a look on the Richmond site, they have an application spec list
Jamie_stafford
Post by Jamie_stafford » Tue Mar 13, 2012 1:44 pm
Just had a look on there and they only fit the front of a 1986-1988 samurai, i will do the rear for now and try a find a front diff from that age. thanks for the help bud
Post by Anton » Wed Mar 14, 2012 8:08 pm
Don't quote me on this, but I don't think the 86-88 samurai is actually a samurai at all - I think it's just a 413, with narrower axles.
I say this because I have an 88 SJ413 which had the narrower 413 axles on it - the Samurai has slightly wider axles (as does my SJ413 now!) - although I *think* the diffs in them are the same size, if slightly different ratios (they're swappable, but not mix and match - stick with 413 or sammy diffs in BOTH axles).
I'm pretty sure the lockrights will fit in any 413, Samurai or Jimny. That's what I've been told, anyway. Same model as Suzuki hasn't done much to change the diffs over the years.
410 ones defo won't fit though.
I think jimnybits sell the lockrights cheap as chips - if the richmond website is confusing, perhaps try emailing jimnybits? They should know what'll fit into what.
Post by twiss » Thu Mar 15, 2012 9:18 am
The 86-88 samurai is definitely a samurai, with the wider axles and higher ratio diffs
During these years they produced Samurais and 413s at the same time.
I dont think they continued production of the 413 or standard samurai after '88 or '89.
In 1990 they started making the Samurai Sport instead. (Facelift model)
You are correct in saying they are the same diffs apart from the different ratio.
Post by Anton » Thu Mar 15, 2012 10:45 am
Thanks, twiss. That clears up some confusion. So Sammies and 413s have the same differentials, just slightly different ring gear ratio? That would mean the locker will definitely fit.
Jamie_stafford
Post by Jamie_stafford » Fri Mar 16, 2012 3:52 pm
My samurai is a 91 im sure its not a sport, how could i tell?
Highlander
Post by Highlander » Fri Mar 16, 2012 3:59 pm
http://www.freecarcheck.org/search
If its the one in your pics then according to this, not only is it not a Sport, its not even a Samurai its an SJ :D
Vehicle Identification
Manufacturer: Suzuki
Model: Sj 413 Vx
Year: 1991
Colour: Green
Fuel Type: Petrol
Engine Size (CC): 1324
VIN: Not available
V5C Issued: Not available
Tax
Tax Status: Licence Not Due
Expiry Date: 01/06/2012
Registration Date: 08/10/1991
6 Month Cost: £71.50
12 Month Cost: £130.00
