gearbox help needed samuarai 413
hi just brought a sj 413 samurai and 1st outing gearbox has completley gone with no warning where can i get a replacement and will any other gearboxes fit straight on or will i have to find the exact model as mine cheers
Re: gearbox help needed samuarai 413
In what way has it gone?
Might just be the springs or pin in the top part if its just hard to find a gear.
Dan
Dan
I was going through a mud pit and the gears just stopped working i can put the gear stick in any gear and nothing will happen there was a smell of like burning clutch as this happened any ideas ?
Ive had the pin in the top of the gearbox that holds the shift lever central snap on me but I could still get 3rd and 4th.
If you push the clutch up and down you should be able to hear a difference in tone as the engine takes up the extra load and spins the input shaft on the gearbox.
That will prove the clutch is still functioning.
I know it sounds silly but are you 100% you didnt knock the transfer box into neutral?
Blimey... Good point...I'd have had the gear box out by now...Would have been upset to find the T-box was in neutraldan_2k_uk wrote: I know it sounds silly but are you 100% you didnt knock the transfer box into neutral?
