Identify parts please
Hi I am trying to identify these components, there is a silver finned item which may be some sort of rgulator and two relays, I believe they are all to do with the head lights. Any help would be appreciated.
- IMAG0790.jpg (872.79 KiB) Viewed 8933 times
Re: Identify parts please
Hi whereabouts are they on the Zook?
Hi this is a Spanish buikt SJJ410 F reg (1988 I think) and the components are next to the fuse board in the NS front footwell.
Have identified the silver finned unit, now need to identify what the relays are for, qnyon help please,
To the best of my knowledge none of those relays are standard. If you could take some photos showing all the wire colours it may help.
You could disconnect one at a time and then see what no longer works
- Highlander
- Can I have a tow
Don't have them on any of mine, might be quicker just to trace the wiring to see where it goes
hi i also have trouble with one of these what is it!! i drive an "F" reg mine is not spanish built the unit was found up behind the glove box whilst doing a wire trace, mine was full of water now it's dried out strange things have started to happen it needs replacing but i dont know what to ask for Help!!
That's the headlights dip dim unit (normally only fitted to Spanish models). The standard fix for these when they play up is to just disconnect it and launch it down the garden. However the normal problem is the headlights staying on all the time.
Unplug it and see if it fixes any of your problems.
