413 oil water serious problem help required!!
Mish413
Post by Mish413 » Wed Jul 04, 2012 5:46 pm
Have got a replacement engine as one of the pistons shattered in last one, have put new head gasket in and engine runs perfectly but when i put water in the rad it comes out of the sump. Im sure this is major but just not sure on how this is happening?!? please any ideas or reasons needed...........
Mish413
Re: 413 oil water serious problem help required!!
Post by Mish413 » Wed Jul 04, 2012 6:05 pm
Is a lot of water not just a little runs like a tap from sump plug! even when engine is not running
Any ideas?????? Is it possibly a cracked lump?
Post by twiss » Wed Jul 04, 2012 7:09 pm
is it possible you've got a water hose going to the wrong place?
If you filled your cylinders up with water it would go down into the sump...
it would take a while to feed through though. is it instant waterworks as soon as you put water in?
Mish413
Post by Mish413 » Wed Jul 04, 2012 7:13 pm
Thats what i thought so i had a good look but nothing obvious.
No it runs straight through pour it in the top of the rad and it flows straight through and out the sump hole even without engine running so can only be gravity.
If there was a large hole somewhere would the engine run so well?
Mish413
Post by Mish413 » Thu Jul 05, 2012 8:25 am
No one got any ideas??
Highlander
Post by Highlander » Thu Jul 05, 2012 9:20 am
Head gasket on correctly? is it the right one?
Post by ScottieJ » Thu Jul 05, 2012 9:28 am
Has your SJ got a brake servo? Are you sure you havent mistakenly put a water pipe onto the wrong point on the inlet manifold like twiss has mentioned. Can you take some pics and post them up of where all your pipework goes.
It would have to be a gaping crack somewhere for that to happen if it wasn't. The only thing that happens if you fit the headgasket on the wrong way around is an oilway gets blocked. Is the head all correctly torqued down? Was it checked that it wasn't warped before fitting it? (would have to be really warped for this to happen though.)
Mish413
Post by Mish413 » Thu Jul 05, 2012 6:39 pm
I got the gasket on right, all torqued properly i will post some pictures shortly
Thanks
Mish413
Post by Mish413 » Fri Jul 06, 2012 4:31 pm
Couldnt get the pictures to upload so i thought i would just take the engine out strip it and start again have assembled all engine out of the sj and am just putting it back in last it took a bit of shaking and it went it fine this time it is being a bi**h! Is there any certain way to do it or procedure?
Thanks
Post by ScottieJ » Fri Jul 06, 2012 4:39 pm
whoaaaah I'm sure you didn't need to go as far as taking the engine out even if you are taking the head off :lol:
You could always upload pics to photobucket etc. and link them across using the IMG code
The main thing I wanted to check was that all the coolant pipes were in the correct places on the inlet manifold.
