Hi
I've got my hands on a cheap 12v winch that hooks over a ball hitch fine for pulling backwards, but what if i wanted to pull forwards.
Any Ideas on how to fit a front toebar without ruining the stock bumper and loosing ground clearance
fittting a front toeball
- Ginger_boy
Re: fittting a front toeball
If i was you i would simply get a recovery bar or similar that you can just put a strap through.
The standard bumper wouldnt hold the weight of half your zuk never mind all of it
- Ginger_boy
Yer sort of got that,
was thinking more the chassis ends or the large piece of tube which id behing the bumper
A nice little thing i have seen is a cut down S3 bumper fitted to a sj
you could then weld a ball hitch to the bumer
