need advice on rollcage pls guys
hamer
Post by hamer » Wed Sep 05, 2012 10:25 pm
had a few scaff poles last week so have spent few hours with my cheap pipe bender
today moulding the poles to the shape of the anus was suprised how good it went,
i welded 3"by2" boxsection to the sill so i can weld the poles directly down on to it,
iv wacked the boxsection with a lump hammer and it aint budged butt dont trust it,
so if anyone has any advise hopefully with some pics of how they made a solid base for an external
rollcage id be very greatfull :)
thanks guys
richy
dazerede
Re: need advice on rollcage pls guys
Post by dazerede » Thu Sep 06, 2012 4:29 pm
what i would do is make some rock sliders and weld to chassis and make some heavey duty bumpers and then weld to them
4” calmini lift kit :)
Post by ScottieJ » Fri Sep 07, 2012 12:59 pm
personally I would advise against using scaff pipe for a roll cage, firstly the galvanisation gives of poisonousness fumes when welding and it's not actually very strong.
48x3.2mm Hrew or blueband tube is cheap, stronger and will make a better cage.
also be careful when using a crush type bender as it is easy to crease the tube therefore making it weaker.
I would also advise tying the rocksliders into the chassis, that will also make for a stronger and safer cage.
A badly built cage is just as if not more dangerous than having no cage and it is there to save your life!
My rock sliders will have a cage attached to them eventually, I have welded 6mm thick spreader plates to the chassis and then welded the outriggers and rock sliders to those as the SJs chassis is not very thick, welding straight to the chassis isn't really strong enough and the chassis could tear in a bad roll over
hamer
Post by hamer » Fri Sep 07, 2012 9:31 pm
ha thanks scotty only naw logged in and iv done identically what you have to support it today :)
my mates got a unit he uses for ther banger racing cars went down ther yesterday to get some ideas,
it bent real nice not one crease at all ,
not planning on climing any large steap hills and aint really planning on rolling lol
butt hopefully it will be strong enof to save my fiberglass roof if i end up on it one day :)
il look into it more before i weld the poles down tommorrow
thanks guys
hamer
Post by hamer » Fri Nov 09, 2012 8:47 pm
thought id get a pic up of the sj with the cage on :)
pritchard182
Post by pritchard182 » Fri Nov 09, 2012 9:37 pm
looks wicked now find me one haha
vitara_mad
Post by vitara_mad » Sat Nov 24, 2012 7:09 pm
did you fill the scaff tube with sand to get it to bend without creasing ???
hamer
Post by hamer » Sun Nov 25, 2012 7:47 pm
no mate
that was the plan but didnt need too
i had a blow torch on stand by too
Post by Tramp » Sun Nov 25, 2012 9:21 pm
It looks good, I like your bumper too what make is it?
Post by Jordi » Sun Nov 25, 2012 9:52 pm
What sort of pipe bender did you use bud? I want to make a cage but not sure what kinda bender to use.
