Advice on brakes
dunnin21
Advice on brakes
Post by dunnin21 » Wed Sep 12, 2012 12:46 pm
I'm breaking a vit at the min, iv took the front calipers off do these bolt straight on to my sammy or will I need discs off vit and any other parts. Thanks andy
Re: Advice on brakes
Post by Darrell » Wed Sep 12, 2012 9:50 pm
Sure you will need the discs as these are vented and therefore wider. Not sure about anything else, but have read that they are a straight swap. Hopefully someone who has done this will give better advice :poke: .
Post by Darrell » Wed Sep 12, 2012 9:56 pm
been and had a search, found this http://forum.difflock.com/viewtopic.php?t=71289
Post by ScottieJ » Thu Sep 13, 2012 9:36 am
Depends on what model vit, swb vits use the same discs, you need the caliper hangers as well, also you need to bleed the calipers with them unbolted and rotated so that the bleed nipples are at the top. I run swb vit calipers on the front of mine.
Lwb vits have vented discs so you need the discs as well.
