suzuki sj413 wiring problem.
suzuki-rob
Post by suzuki-rob » Thu Sep 20, 2012 5:15 pm
I have two problems at the moment one being ;
does anyone know where the wires should go from condenser both sides if possible i know one side goes to coil but is it the plus or minus?
secondly I have a alternator that takes around plug but my plug is rectangle and wont fit. it has three wires two heavy duty white and yellow stripped wires and one white and red wire anyone that could shed some light on theses problems much appreciated
:suzuki:
Re: suzuki sj413 wiring problem.
Post by Darrell » Thu Sep 20, 2012 7:16 pm
The round plug to the alternator is connected like this.
Untitled .jpg (70.4 KiB) Viewed 13022 times
The condenser earths via the/it's body and the one wire is connected to the same wire as goes to the points.
Points diagram.jpg (27.82 KiB) Viewed 13022 times
suzuki-rob
Post by suzuki-rob » Thu Sep 20, 2012 10:07 pm
Cheers very big help
Post by Darrell » Sat Sep 22, 2012 12:16 pm
Re-read this and thought condensor 413 engine ????
So maybe it's the noise suppressor ??
413 Coil Wiring.jpg (60.64 KiB) Viewed 12982 times
413 Ignition circuit.jpg (20.18 KiB) Viewed 12982 times
timwilks13
SCUK Website Padawan
Post by timwilks13 » Mon Jul 08, 2013 3:50 pm
quick question about that alternator image, in the round connector what is the middle top spade for?
Post by twiss » Mon Jul 08, 2013 6:32 pm
I was going to mention that, I think on the one that just died on me and the one trotter kindly lent me, the terminal for the two fat cables is on the back of the alternator
and I'm pretty sure the top wire goes to the dash light on mine but I will check on that.
ive seen one before that only has the top (in the picture) wire and not the other two
Post by Darrell » Mon Jul 08, 2013 6:51 pm
This is what's on mine..
Pin D does nowt :thumbup:
Post by twiss » Thu Jul 11, 2013 11:36 am
Just so you know I just checked my old one that I removed on friday...
The battery light wire was connected to the connection marked D in the above pic
Just bear in mind that some alternators maybe different, and if the dash battery light doesn't come on, it may be worth trying the other pins
