Sj 1600 engine mount
dunnin21
Post by dunnin21 » Mon Nov 19, 2012 11:09 am
Still doing my engine swap. I'm ready to put the engine in now can anyone tell me were the new hole has to be drilled on the O/S engine mount as I'd like to do it now while engine still out but not sure we're to drill. Thank again guys.
Re: Sj 1600 engine mount
Post by ScottieJ » Mon Nov 19, 2012 1:09 pm
I couldn't tell you I made custom engine mounts.
I would personally drop it into positon and loosely bolt the other mounts up first to work it out.
the last thing you want is for someone to tell you where to drill it and for you to go to fit the engine to find that they gave you the wrong measurements ;)
Post by dan_2k_uk » Mon Nov 19, 2012 4:45 pm
both times I have tried to get that hole in the right spot I have ended up drilling it too high and having to use a spacer.
best to offer it up like Scottie says
dunnin21
Post by dunnin21 » Mon Nov 19, 2012 10:45 pm
Ok thanks, so I bolt engine to box then bolt ns mount up and I should have it sum were near
Post by dan_2k_uk » Mon Nov 19, 2012 11:06 pm
Yeah
dannytrigger
Post by dannytrigger » Wed Feb 06, 2013 2:36 pm
How did you get on with the other mount mate ?
Post by dan_2k_uk » Wed Feb 06, 2013 4:37 pm
He will have got it done. It literally couldn't be any easier.
Bolt old 1300 mounts to 1600 block and offer it up with the spreader plate removed from the drivers side.
bolt up the passenger side and rear mount and you will see where the stud rests on the drivers side and just drill it out.
If it ends up too high just use a thick square washer.
dunnin21
Post by dunnin21 » Fri Feb 08, 2013 10:09 am
Yeh got it sortted no probs thanks
