Carb Yet Again
Gardiner
Carb Yet Again
Post by Gardiner » Fri Dec 28, 2012 6:39 pm
Ok so today fired her up and adjusted timing to 10 deg BDTC done tappets etc and she purrs lovely.
Problem is Revving and adjusting mixture I have followed all the things I have read on internet and to no avail.
So i am edging towards carb not playing ball so I am now thinking get a original carb and manifold and see what difference it makes what model Vitara should i be looking for for the Donor Carb and Manifold.
Many Thanks
colinl
Re: Carb Yet Again
Post by colinl » Fri Dec 28, 2012 10:44 pm
what sort of carb is it you are trying to set up?
Gardiner
Re: Carb Yet Again
Post by Gardiner » Sat Dec 29, 2012 6:13 pm
Its a 1600 8v with a SU Carb
Re: Carb Yet Again
Post by ScottieJ » Sat Dec 29, 2012 6:51 pm
To be honest you'll probably have better luck servicing and rebuding the SU carb. Chances of finding a good original carb is probably pretty slim.
Gardiner
Re: Carb Yet Again
Post by Gardiner » Sat Dec 29, 2012 9:39 pm
Thats the trouble I have done needle and spring renewed all the rubbers and cleaned thourghly and it still wont run sweet so I am not sure what else I can renew !!!
Re: Carb Yet Again
Post by ScottieJ » Sat Dec 29, 2012 10:30 pm
Can you post up some detailed pictures of your carb set up please?
These are quite simple carbs so I'm sure we can work something out.
