Spray
OllieSJ
Spray
Post by OllieSJ » Tue Feb 05, 2013 9:33 pm
i want to spray my sj its orginal colour but want it to be cheap and effective not really wanting to spend more that 200 on it
dazerede
Re: Spray
Post by dazerede » Tue Feb 05, 2013 9:59 pm
Mine only cost me about 150
1,litre tin was about 12.00
4” calmini lift kit :)
Re: Spray
Post by turbo-tom » Tue Feb 05, 2013 10:00 pm
well to get it matched to the exacted colour wont come cheap.
dazerede
Re: Spray
Post by dazerede » Tue Feb 05, 2013 10:05 pm
Look through this page of other peoples paint
http://forum.suzukiclubuk.co.uk/vi ... lit,paint/
Re: Spray
Post by Jordi » Tue Feb 05, 2013 11:27 pm
To spray it yourself celluose paint and thinners is the cheapest but quite hard to get now as it's a bit toxic. Paint, primer and thinners should be less than £50. You need a gallon of thinners, litre of self build primer and 1.5lts of self laquer colour. Shop around and you'll get a compressor and spray gun for under £150. Compressor will run out of air every 2mins like.
Alternatively you need to do all prep work yourself, weld panels up, fill any bits you want filing and rub the whole car down with fine rubbing paper (wet and dry). Mask of or remove all trim not to be painted. If your lucky a bodyshop will blow it over for about £250. For that kinda price it wont last long. Don't expect a showroom finish.
Spraying cars isn't cheap. My compressor was £300, another £100 for a spray gun. I probably spent £100 on paint and consumables (tape, thinners, fillers, rubbing paper)
If it's off road only just roller it.
Re: Spray
Post by dan_2k_uk » Tue Feb 05, 2013 11:58 pm
Mine will never see anything but a brush!
Didn't even need any masking tape (or attention to detail :D ) as every part was totally stripped.
Those window seals are a bugger to get back in tho and dont even mention the windscreen!!!
Re: Spray
Post by Jordi » Wed Feb 06, 2013 12:01 am
Windows are a piece of piss. Did you use the string method?
Re: Spray
Post by dan_2k_uk » Wed Feb 06, 2013 12:14 am
Yeah.... It was more getting it out that was the problem :argh:
Re: Spray
Post by Jordi » Wed Feb 06, 2013 12:24 am
Takes two people mone has to sit in a seat and place feet on the window applying gentle pressure along the top of the windscreen.
The other has to work a screwdriver along the outer seam gently prising it out.
Took my about 5 mins a window.
Re: Spray
Post by Jordi » Wed Feb 06, 2013 12:25 am
Couple of mistakes in that post. We'll blame the booze.
