Page 1 of 2
2000 Suzuki Swift Radio
Posted: Fri Feb 08, 2013 3:02 pm
by luke 626
The radio has stopped working, along with the cig lighter, but the clock works fine. I cannot find a fuse for these, i have checked the radio connections and there is no power going through them.
Where is the fuse??? or what is it called??? i cannot find anything under the bonnet or in the engine bay!
Re: 2000 Suzuki Swift Radio
Posted: Fri Feb 08, 2013 4:51 pm
by dazerede
On my sj 410 there is a fuse box I. The footwells of the drivers side
And it should be the bottom right for the cigarette lighter and the radio
If that doesn't work
What mode do u have ? Like 413 or 410 or samurai
Posted: Fri Feb 08, 2013 4:55 pm
by dan_2k_uk
Dazerede he has a suzuki swift by the looks of it.
Posted: Fri Feb 08, 2013 4:59 pm
by dazerede
dan_2k_uk wrote:Dazerede he has a suzuki swift by the looks of it.
I didn't see that well
Posted: Fri Feb 08, 2013 5:01 pm
by ferris
There is probably a second fuse box inside the car. Probably somewhere under the steering wheel or maybe on the passenger side.
Posted: Fri Feb 08, 2013 5:55 pm
by luke 626
thanks for the quick replies, i made an error in my post i meant to say under the steering wheel and in the engine bay.
Under the steering wheel there is a small brown box, with very little fuses, ive never seen a modernish car have so little fuses, i know they were first released in 1986, but this car has all the options!!
theres is none called radio etc, which is strange because there usually is.
Something else i can add is that the digital clock is connected to the same loom and that works fine.
The trouble is im in a hurry in selling this car for my boss and not having a radio will seriously de-value it.
Posted: Fri Feb 08, 2013 6:25 pm
by Edweird
The radio might have it's own fuse. I've seen some cars with inline fuses connected to the radio. They sorta look like household fuses but longer.
Posted: Fri Feb 08, 2013 6:43 pm
by Darrell
Found a circuit diagram and it shows 2 fuses , having another look online they are up under the dash somewhere.
Posted: Fri Feb 08, 2013 7:15 pm
by luke 626
Great thats it!!!!! thank you very much ill sort that out in the morning!!
Posted: Sat Feb 09, 2013 11:20 am
by luke 626
Looked for it i cant find it, i could never be an auto electrician
