wheel studs needed brand new
Posted: Sat Apr 27, 2013 4:39 pm
by dazerede
Can anybody help me as I am wanting 18 new I mean new wheel stud bolts
Plus 8 washers and bolts to hold the drum onto the shafts
As the studs that hold the drum on is the same size as the ones that hold the wheel on
I have around hand ones but I want new ones as some are crossthreaded and a bit damaged
Re: wheel studs needed brand new
Posted: Sat Apr 27, 2013 4:41 pm
by dazerede
Also I need a new wheel spacer stud it is a 30mm wheel spacer looks like this
Posted: Sat Apr 27, 2013 4:44 pm
by dazerede
Also I need a couple of these that hold the copper pipe into the cylinder I need them new aswell
Posted: Sat Apr 27, 2013 6:01 pm
by Ladaman
The brake pipe nut is an easy one.
If you go to a motor spares shop they will be able to make you a new brake pipe with the correct nuts. Just remember to take the nut, an old bit of pipe to show them the type of flare needed, and the length.
I cant help with the stripped studs, but someone else will I'm sure.
Posted: Sat Apr 27, 2013 10:23 pm
by Darrell
Posted: Sun Apr 28, 2013 9:04 am
by dazerede
Ye i seen them washers and nuts but im a after the bolts aswell
Ye going to POP up to motor parts direct on tuesday to sort out the cylinder thing
Posted: Sun Apr 28, 2013 10:26 am
by Darrell
This is the only site in the UK I can find selling any.
http://www.walldonwaypartsshop.co.uk/pr ... 9119-12003 They only have 6, you may end up going to a main stealer for them
Posted: Sun Apr 28, 2013 1:14 pm
by dazerede
Yep that's the ones darrell but I need 15 but they only have 6 in stock
Mmm must call Suzuki sanfords then
Chears darrell
Posted: Sun Apr 28, 2013 1:49 pm
by dazerede
Right I have sorted out my wheel spacer problems I emailed a few people who sell spacers and they told me to buy this ok they are a bit longer and wrong colour but its all good
Click Here for Ebay Listing
1/3 problems sorted
