Accelerator bracket.
The Bird Man
Post by The Bird Man » Tue May 14, 2013 9:39 pm
Hiya chaps, another question. I've got a small rust hole where the accelerator bracket should be help on place and it's hanging loose. Will it be ok to bolt a plate onto the bracket and then bolt that plate to the body ? Or will it be best to weld it ? Also I'm after some new wheel arches, I like the defender arches very much but not the price tag that goes with them :roll: Are there any cheaper alternatives ? Thanks, again :D
Re: Accelerator bracket.
Post by Jordi » Tue May 14, 2013 9:53 pm
Free automotive steel did for me on the front and my "make do" HGV placcy rears have lasted 4 years.
Post by twiss » Wed May 15, 2013 11:24 am
You should be ok with bolting a plate onto the bulkhead then bolting your accelerator pedal onto that... but you should be aware that although it works as a temporary fix, the bulkhead behind it will still get more rusty! Drilling various holes in it won't help, and an extra layer of metal is just something else for mud and water to get stuck behind, possibly making the rusting even worse!
It will probably need to be welded at some point, better to get it done sooner rather than later before it gets worse
(speaking from experience)
Post by Jordi » Wed May 15, 2013 5:07 pm
Cut all the rust out and weld a new plate in. Best way!
As twiss says more hole will lead to more rust!
Post by twiss » Wed May 15, 2013 5:21 pm
Ive spent years bodging things back together and come to the conclusion that its really not worth it
(Unless you're really in a hurry, and will do the proper job afterwards ;) )
Post by turbo-tom » Wed May 15, 2013 5:30 pm
twiss wrote:Ive spent years bodging things back together and come to the conclusion that its really not worth it
for example Steyning car park, hose "well we have broke the jubilee clip" one thing for it "CABLE TIES :D " to be fare they got us out of shit :lol:
Post by twiss » Wed May 15, 2013 5:32 pm
lol if i had a spare clip we would have used that!
indeed it did get us out of the shit, and we made it to halfrauds!!!
Post by turbo-tom » Wed May 15, 2013 5:35 pm
twiss wrote:lol if i had a spare clip we would have used that!
yep with about 2 minuets to spare! :hahaha:
Post by Jordi » Wed May 15, 2013 5:41 pm
I used cable ties to hold a turbo pipe onto a 51 plate ERF truck. Held a treat
Post by turbo-tom » Wed May 15, 2013 5:43 pm
Jordi wrote:I used cable ties to hold a turbo pipe onto a 51 plate ERF truck. Held a treat
:hahaha: taking cable ties to the extreme!
