DIY Fuel tank
DIY Fuel tank
Post by Jordi » Wed May 22, 2013 1:54 pm
I'm looking at getting a fuel tank made. Probs 50ltr so its a bit bigger than standard.
To keep costs down and make fitment easy i'm looking to use the original sender unit.
Am i right in saying as long as the fuel tank is the same depth as a standard tank the sender unit will still be accurate as it will still have the same up/down movement?
Your thoughts please.
windsor
Re: Fuel tank sizes and sender units
Post by windsor » Wed May 22, 2013 1:57 pm
As long as your sender has full travel it will be fine just if the tanks deeper ull have a bigger empty so to speak
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
Post by Jordi » Wed May 22, 2013 1:59 pm
I'm looking at something same width and depth as standard but a bit longer and completely square instead of rounded.
windsor
Post by windsor » Wed May 22, 2013 2:04 pm
Should be fine then as its messures the travel i.e. up and down not volume it will still say full at full and empty aat empty just take longer to go down and cost more to fill lol
1994 sj 413 sierra
cd players
99% rust free
alloys
bukets
Post by Jordi » Wed May 22, 2013 2:07 pm
The cost isn't an issue. If it needs fuel it needs fuel, lol. Day to day i only put £10 -£15 in every week or two.
When out laning it can become very thirsty and it would be nice to have a bit extra capacity.
Post by Jordi » Wed May 22, 2013 2:10 pm
Anybody got a tank sat about they could measure the internal depth of for me?
Saves me messing on with mine too much.
Thanks
Post by Jordi » Fri May 24, 2013 1:34 pm
Tell me if i'm wrong. Other wise this could be an expensive mistake.
A fuel tank 65cm x 25cm x 30cm is 48.75lts standard tank i measure at approx 27cm deep so i i make mine deeper it just means the fuel gauge will read empty when i still have some left. Correct?
Standard tank is 35lts?
Post by Jordi » Fri May 24, 2013 1:44 pm
Haynes says its 10.6gal which is 48lts anyway.
So if we go 65x28x30cm its 54.6lts. Which sounds nice. An extra gallon of fuel. Or 65x30x30cm is 58.5lts. But is about as big as i want in the space available. 12.8 gallon so just over 2extra gallon which should mean another 60miles between fills when doing lots of miles.
windsor
Post by windsor » Fri May 24, 2013 2:25 pm
Yeah your rite if u go deeper it will show empty when its not
1994 sj 413 sierra
cd players
99% rust free
alloys
bukets
Post by Jordi » Fri May 24, 2013 2:26 pm
Think i'm settled on 65x30x30. As said, it fits the available space well. Tried to get a quote today but the lads who do the pricing are at a funeral. I'll be goong round next week to see them at some point.
