A bit of a different request to most.
Has anyone got a Jimny M13A engine, or more specifically the fly wheel available to carry out a quick measurement for me?
I need to know the size of the step on the fly wheel from where the friction plate runs, to where the cover plate bolts on. I think its about 3mm. It dimension X on the attached drawing.
If it could be measured with a digital vernier or something accurate it would be a big help, but just by a rule will get me out of a sticky situation.
Thanks.
Jimny flywheel dimension
- Ladaman
- Suzuki Guru
- Suzuki Jimny flywheel.jpg (27.76 KiB) Viewed 3364 times
- Ladaman
- Suzuki Guru
Re: Jimny flywheel dimension
I've got this measured now.
If it is ever needed for future the dimension is 2mm dead on.
I just need to adjust the spacers I made now.
