LJ 80 WALL CHART
LJ 80 WALL CHART
Hi all been looking throught some of the paper work and came across this wall chart for the lj.
- use.JPG (1.46 MiB) Viewed 12286 times
Re: LJ 80 WALL CHART
I have a copy of it as well. I also have it scanned in and saved as a TIFF and PDF. I sent a copy to Scotty to put on the website but not sure if he got it. Had to do it by post as my work PC doesn't want to send it electronically
Ah yes I have got the CD juncopartner, I moved house not long after you sent it and it fell down the back of the shelf it was put on so it only found its way back to me a month ago
still havent event put it in my PC so i'll do that tomorrow
That wall chart looks like it was written for kids
Wonder if anyone has an SJ version?
Would go well on the garage / bedroom wall. Especially if i have a baby boy.
Hi all,I think its to big to be copied, will take it into town tomorrow (34x23 inches), to see if it can, its also 2 sided, its in japanese on the back, their is also a LJ sales page / leaflet, and a cat for the sj..
i think it would look good as a tee shirt..curt
two sided sales leaflet
- LJ pages 005.JPG (1.92 MiB) Viewed 12244 times
If you want it copied you will need to find someone with an A1 plan printer/scanner. Usually someone who does Architetural plans. But if you print it off the Tiff I sent Scotty it will be better quality as i have used microsoft paint to remove the creases, shadowing etc that will show up otherwise.
Well I managed to convert the chart back to a smaller JPEG , couldn't get the larger file to upload so here thet are. Not sure if it means they won't be as good a quality if you print them off at the original full size A1, but I can always E mail the larger file direct if anyone wants it.
- Suzuki LJ80 Wall Chart 02.jpg (952.58 KiB) Viewed 11875 times
- Suzuki LJ80 Wall Chart 01.jpg (1.02 MiB) Viewed 11875 times
