marshal Ventura any good off road ?
- littlesammy
hi.,ive got marshal Ventura 33x12.5x15 tyres on anus wrangler rims sitting on my little sammy at the moment and wondered if they're going to be any good off road.
what do you guys reckon.?
cheers
liam .
cheers
liam .
87 Samurai with added spice !
- The Heretic
Re: marshal Ventura any good off road ?
Look like a copy of the Khumo Ventura KL57? The Khumo get good reviews, so who knows.
- turbo-tom
Id doubt it from the tread patern. However some at's can be really good and some can be garbage.
They are MTs not ATsturbo-tom wrote:Id doubt it from the tread patern. However some at's can be really good and some can be garbage.
They're a pretty standard mud terrain pattern so in most scenarios they'll do fine, only in thick sticky clay and some steep climbs you might find you want more traction.
Are you mostly going to be doing trials/pay and plays or a bit of everything including laning? If the later they'll be fine.
On the plus side with less aggressive tyres you are less likely to break stuff if you are thrashing it.
- The Heretic
They look very similar to me.
- image.jpg (138.64 KiB) Viewed 6176 times
- image.jpg (159.59 KiB) Viewed 6176 times
He's got the older style ones that look more like the old BFG MTThe Heretic wrote:They look very similar to me.
- The Heretic
I looked at a pic of his SJ in his introduction threadThe Heretic wrote:How on earth do you know that?
- The Heretic
That's cheating and you will not receive any cookies from now on.
- littlesammy
Thanks gentlemen.,looks like i will be relying on the Rob Storr crawler box and air locker then.!
