sticky starter.. I think..
Jay18
Post by Jay18 » Thu Aug 15, 2013 4:12 pm
when I turn the key to start my zuk up it clicks as if the solenoid is engaging but no spiny spiny, after doing it sometimes two times sometimes even 3 or 4 it then starts, basically can I fix it and if so how? also is it what I think it is and it's sticking?..
thanks, James..
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: sticky starter.. I think..
Post by Edweird » Thu Aug 15, 2013 4:13 pm
Might need to rebuild the starter.
Jay18
Post by Jay18 » Thu Aug 15, 2013 4:18 pm
Scottie has just said that lol so it's just a case if stripping it and cleaning it? what should I use to clean it? obviously nothin wet lol
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by ROBBIE » Thu Aug 15, 2013 5:26 pm
There used to be a write up in the tech section on a clicky starter fix, but cant find it :er:
I used it on mine as it kept clicking and then not and I was getting sick of it, I pulled it out a few times to clean. Havent had a problem with it since ;)
Post by twiss » Thu Aug 15, 2013 5:43 pm
does it just go click click click?
may be that the small starter wire is corroded and not letting enough juice through...
seems to happen a lot!
be warned, this is not really a very good way of starting your car and make 100% sure you're out of gear! -
take off the small wire from the starter solenoid and bridge the terminal it came off to the solenoid terminal with the chunky cable going to the battery positive terminal.
Use a screwdriver or similar, preferably with a plastic handle... ive never had a shock from this myself but it doesn't hurt to take precautions!
it will probably spark when you make contact so be careful!
if this starts it no problem it would probably be worth doing the clicky starter fix
you need:
> 30a relay (4 or 5 pin)
> 30a rated wire
> fuse holder (waterproof is best) and (surprise surprise) a 30a fuse
> crimp connectors (rings and spades)
> crimp tool
> a screw or a bolt
> drill and suitable size bit
1. pick somewhere to mount your relay, drill a hole and attach it... I usually use the bar that goes from the front of the wheel arch (inside the engine bay) to the back of the headlight. probably best to make a new hole and not use the existing hole for the head/side light earth wires.
2. take the small wire off the starter and attach it to pin 85 on the relay (pin numbers marked on the relay plastic). you may have to change the connector to a spade, if it is a ring
3. wire from pin 86 to an earth point (i usually use the hole i mounted it to)
4. now you should be able to test the relay, if you turn the key to the start position, the relay should make a clicking sound
5. connect your fuse holder to the battery positive terminal, then use a length of wire and connect it to pin 30 on the relay
6. now connect pin 87 to the small connector on the starter motor and insert your 30a fuse
Now when you turn the key to the start position, the relay will click and connect power directly from the battery into the starter. This should fix your clicking starter, and you can do it for less than a tenner! :)
Post by Jordi » Thu Aug 15, 2013 11:30 pm
I love your write up on how to start it Twiss. Very H&S conscious. Sure that was exaclty how Suzuki intended things to be done. :hahaha:
I'd NEVER try any thing like that of course. :hahaha:
Post by turbo-tom » Thu Aug 15, 2013 11:57 pm
Sounds like what I had to do to get my starter motor to work with the screwdriver.
Post by ROBBIE » Fri Aug 16, 2013 9:26 am
On one of the boats I worked on we had a spanner for that job, or as it was called the key
