a question for the southern people
monkey
Post by monkey » Wed Aug 28, 2013 8:17 pm
Where does everyone get there sheet steel from, as found some tin worm wholes that need plugging up.
And as usual don't have any when i need some.
Ladaman
Re: a question for the southern people
Post by Ladaman » Wed Aug 28, 2013 8:35 pm
Being a "Northerner" I'm not really being asked this, I've just butted in. :hahaha:
If it's just bits and pieces you want, look up a local fabrication shop, they generally give you off cuts from the scrap bin, or just charge you a token amount.
They will probably cut you specific things too if you wanted, and at a good rate.
Always worth asking.
rory-ray
Post by rory-ray » Wed Aug 28, 2013 8:41 pm
Yellow pages,look for engineering places and metal fab's there never short of anything, a small amount of beer tokens will see you fine! Especially on a Friday people are more inclined to have a bit of cash n there pocket ive found
We got 2x sheets of 3foot by 4 foot steel chequer plate the other week for £10!!
1994 Pick Up Converted Vitara
+2" Springs, Pro Comp Front And Rear Shocks, 31" Marshalls On 8j's, Front Winch Bumper, OMP Steering Wheel And Boss, Bucket Seats, Stripped Out, Black Bonnet With Scoop, Few Dents And Scratches, Little Rust!!!
Post by turbo-tom » Wed Aug 28, 2013 9:15 pm
local fabrication companys do it for me. and i advertise for them so i get discounted prices win win :)
NylonAdmiral
Post by NylonAdmiral » Wed Aug 28, 2013 9:24 pm
I get mine from a place called Devizes Steel Supplies as they're about 10min away from me but unfortunately quite a way from you.
Pretty much any steel yard / fabricator / engineering shop should be able to supply you what you need I would think?
Post by ScottieJ » Wed Aug 28, 2013 9:40 pm
I used to work in a sheet metal fab shop so I just go see my old boss :smokin:
might even try and get my job back next time :er:
Post by Jordi » Wed Aug 28, 2013 9:46 pm
If i'm wanting decent steel i buy from a local steel stockholder. For smaller odd n sods i ask about for scraps at local engineers / machine shops.
If you catch them on a good day it can be for nothing.
Post by mike harris » Wed Aug 28, 2013 9:52 pm
Pyramid steel? In aldershot?
Go onto metal supermarket and you can have it delivered.
I bought a sheet of eBay the other day !! It's really cheap on there 350 mm x 350mm x 6mm £16 delivered !!
Mike
Post by Jordi » Wed Aug 28, 2013 9:57 pm
mike harris wrote:Pyramid steel? In aldershot?
Mike
Hmmmm..... I call that an off cut / scrap, it's only 13.5" square. I got same size (roughly) hardox wear plate FOC from a engineers i collect from.
monkey
Post by monkey » Wed Aug 28, 2013 11:59 pm
Well i'm really after a 8"x4" sheet of 1mm/1.2mm, as i am going to need a fair bit for the unimog that i've got to sort out too.
But just wanted to see if there was anywhere that some of you guys go/recommend.
