handbrake on diff
ikuzusdink
handbrake on diff
Post by ikuzusdink » Thu Nov 28, 2013 8:08 pm
which wud be the better of the 2 handbrakes for the sammy the drum or the disc conversion cheers chaps for help n advice :thumbup:
Re: handbrake on diff
Post by Jordi » Thu Nov 28, 2013 9:08 pm
Most disc conversions use the SJ transmission drum handbrake and front calipers and discs for the rear conversion.
If set up properly the drum transmission brake works ok. If set up badly it's useless.
Fairly sure muddyzook do a rear conversion that uses rover calipers and can include a handbrake too.
Alternatively X-eng do/did make a disc transmission brake.
Post by twiss » Fri Nov 29, 2013 9:13 am
Ive got the twin handbrake drum setup on my 93 samurai... and I will be converting to rear discs and a prop brake! The drum prop brakes aren't that good, but then again neither are my ones!
I'd rather have proper disc brakes all round and a rubbish hand brake though...
Post by Jordi » Fri Nov 29, 2013 1:21 pm
Like wise, I have the rubbish transmission brake and my disc brake kit is in a workshop 200miles away. I must go to Andys one day soon.
Post by Edweird » Fri Nov 29, 2013 1:43 pm
The prop handbrake works alright if it's adjusted properly. I may or may not have done the occasional handbrake turn in mine.
Post by twiss » Fri Nov 29, 2013 4:33 pm
thats the benefit of mine... it loves handbrake turns (until the shoes get un-adjusted and the handbrake turns crap)! although saying that, who needs to handbrake turns when you have rear wheel drive?!?!?!
Post by Edweird » Fri Nov 29, 2013 4:36 pm
twiss wrote:thats the benefit of mine... it loves handbrake turns (until the shoes get un-adjusted and the handbrake turns crap)! although saying that, who needs to handbrake turns when you have rear wheel drive?!?!?!
When I'm parking rather than cornering.
Post by dan_2k_uk » Fri Nov 29, 2013 4:39 pm
Edweird wrote:The prop handbrake works alright if it's adjusted properly. I may or may not have done the occasional handbrake turn in mine.
You don't take yours for a monthly mud bath :D
