Cant get rear drum off
MPD123
Post by MPD123 » Thu Dec 05, 2013 7:31 pm
87 413, handbrake on rear prop.
There is one blanking grommet on the backplate but does not seem to reveal adjuster to back off brakes, tried the tapping all around drum with FBH, tried pry bars and twatting it with hardwood block on inside drum edge...
Other one came off p.o.p
My pre MOT work has not started too well !
Re: Cant get rear drum off
Post by Jordi » Thu Dec 05, 2013 9:18 pm
Are we talking transmission drum brake? Or rear wheel drum?
If its the transmission drum, sounds stupid, you have removed the flange nut?
Post by twiss » Fri Dec 06, 2013 12:46 pm
its a prop brake...
Post by Jordi » Fri Dec 06, 2013 4:06 pm
My question stands. Flange nut removed?
MPD123
Post by MPD123 » Fri Dec 06, 2013 6:34 pm
Tis the O/S rear drum,
Sorry if the first line of my post was misleading, I was trying to identify the braking set up, the title did say Cant get rear drum off, lol.
Any advice appreciated as Im at head butting windscreen stage
Post by Darrell » Fri Dec 06, 2013 8:58 pm
Well the manual says use a slide hammer.
I think people put the wheel on the wrong way round and hit it :shock:
Post by Jordi » Fri Dec 06, 2013 10:00 pm
Slide hammer or just undo the drum nuts and bray the wheel with a big hammer.
Rhinoman
Post by Rhinoman » Fri Dec 06, 2013 11:59 pm
I just put the wheel back on and give it a kick or two. Make sure its secure on its stands before you do that - no scissor jacks!!
kiwizook
Post by kiwizook » Sat Dec 07, 2013 2:15 am
it's the hand brake drum guys!
just make sure you back the shoes off completely, release the handbrake, remove the centre bolt, and it should come off. if it doesn't, you might have to hook a slide hammer on it, and just work your way around, prying it off
Post by Darrell » Sat Dec 07, 2013 11:40 am
No it's not :poke:
:tongue:
:D
